1 страниц (8 вхождений)
lookup fuction - Сообщения
I would like to have a function like lookup (vlookup, hlookup) in smath.
thank you.
thank you.
João Felipe Seráfico Melo 06.03.2023 10:09:00
findrows function within Special Functions plugin is what you're looking for, soomoon
WroteI would like to have a function like lookup (vlookup, hlookup) in smath.
Find Index Key Code is lot more powerful.
Assume your Customer wants more information from his bar diameter
you can give all pertaining informations ...
Add price column, material, delivery ... etc.
bar size Findndex KeyCode.sm (10,33 КиБ) скачан 1222 раз(а).
Look within!... The secret is inside you.
Eng. NDTM Amarasekera - Sri Lanka
João Felipe Seráfico Melo 06.03.2023 10:05:00
Jean, your example shows EXACTLY what findrows does.
WroteJean, your example shows EXACTLY what findrows does
Yes for that simple application.
FindIdx(V,x,col) gives me more for advanced Engineering works
Thanks for the observation.
https://en.smath.com/forum/yaf_postst673_lookup.aspx
Check thread above. You may find it useful.
You can look forum for your questions by searching too.
Searching may result with a ready answer to a question.
findrows() function revisited.
As a part of a project undertaken to study flows of some perennial streams in Sri Lanka,
a particular stream, located far away from Colombo, was selected and a Rating Table (RT) was
prepared relating water levels to flows. This process took a few years so that the
data would almost cover reasonable range of depths for practical reasons, excluding severe floods.
During this period, an electronic device was also constructed to measure water levels (WL) and
transmit as digital signals to control station in Colombo.
However, the numerical values of transmitted WL had more than 6 decimals,
whereas the Rating Table (RT) was calibrated only to 2 decimals. Hence, initially WL values
had to be refined to 2 decimals for use with RT values.
Earlier a vlookup function which was posted in the forum was used, but it took a long time to process
But when the findrows function was available, data processing was dramatically fast.
Both Excel and SM files must be in the same folder.
Cheers
1.July WL&RT.xlsx (29,52 КиБ) скачан 944 раз(а).
Find_Flows-R1.sm (26,11 КиБ) скачан 1317 раз(а).
Find_Flows-R1.pdf (234,55 КиБ) скачан 855 раз(а).
Cheers
Mark R Harris 08.03.2023 16:34:00
