1 страниц (14 вхождений)
error in a system of equations - impossible to get or set an item because it does not exist - Сообщения
"roots" does not work with the units. You must adimensionare equations, or you can try the other features present in the plugin (eg "FindRoot" present "Nonlinear solvers" plugin)
WroteI tried another function but it still gives me an error...
It's a huge system, and generally does not accept all initials same.
I would zap units first. This kind of solving should have it be
solved from P & P [Pain & Prestige] as it reflects real project
that does come out of the blue. Even Mathcad Given/Find may fail
or pedal through constrain.
Attach the work sheet ... some source reference as well.
here is the spreadsheet
calcoli.sm (46,18 КиБ) скачан 703 раз(а).
it is a system of equations derived from the condition of dynamic equilibrium in the stationary curve motion of a bicycle
Wrotehere is the spreadsheet
1. equalities [1,2,3] are consistant 'N'
2. equalities [4,5,6] are inconsistant 'mixed units'
calcoli.sm (52,58 КиБ) скачан 639 раз(а).
You must make the system consitant before attempting solve.
WroteI tried to use the solve function but it still gives me an error saying that S is not defined
Did you read my reply just before your visit ?
WroteWroteI tried to use the solve function but it still gives me an error saying that S is not defined
sorry, when I wrote, I didn't notice your message
Hi. Try this setup, using al_ library. I don't know if using better guess values can get better results (eqn 3 and 4 don't get good results)
calcoli.sm (50,31 КиБ) скачан 689 раз(а).
WroteHi. Try this setup, using al_ library. I don't know if using better guess values can get better results (eqn 3 and 4 don't get good results)
Hi, thanks for the reply, but I think I found the error. The system I wrote has two linearly dependent equations, and for this reason it cannot find a solution.
I will have to modify the whole problem.
Hello Alvaro,
The attached CSTR [SS 6179] example is offered differently,
it is initialized from random guesses: success.
Solve al_nleqsolve CSTR.sm (38,81 КиБ) скачан 683 раз(а).
Alvaro 12.11.2019 13:29:00
WroteWroteHi. Try this setup, using al_ library. I don't know if using better guess values can get better results (eqn 3 and 4 don't get good results)
Hello Alvaro,
Hi Jean. Thanks, very interesting.
![2019-11-06 08_14_22-SMath Studio - [calcoli.sm_].png](/ru-RU/files/Download/PasomE/2019-11-06-08_14_22-SMath-Studio---[calcoli.sm_].png)
