[XlsxImportExport] Exporting Matrix into xlsm File
[XlsxImportExport] Exporting Matrix into xlsm File - Exporting a Matrix and exporting into xlsm file of excel - Сообщения
#21 Опубликовано: 28.10.2018 05:53:31
dont understand what you mean.
If I use your first SMath Studio worksheet with the latest workbook it seems to work for me.
smath worksheet from post #1: Test_#1.sm (8,49 КиБ) скачан 1279 раз(а).
excel workbook from post #18: Wallthickness.xlsm (93,16 КиБ) скачан 1318 раз(а).
This works for me.
In your latest worksheet
- first import function name ends with "M" instead of "X" in the subscript that is a function not defined
In post #18 you changed the content of the SMath worksheet.
This is the typo I was talking. As you correctly wrote in first post, it should be:
- in second import the column A of the excel worksheet returns several circular reference exceptions (there aren't stored values even opening it with excel and the plugin isn't able to calculate one... I might return 0 or the cell formula...)
This is the new range you are trying to import in the SMath worksheet #18. The range rewritten top-left:bottom-right is A5:G150. The plugin fails loading the first column (I see a circular reference exception in the debugger, thrown by the ClosedXML library), that is something I'll look into.
#22 Опубликовано: 28.10.2018 07:27:14
Stefan Müller
Stefan Müller
0 сообщений из 45 понравились пользователям.
Thank you! Best regards!
