Mathcad Toolbox - Contains analogs of functions from Mathcad - Messages
Now x in simple D(t,x) definition must be a scalar.
iode.examples.sm (204.21 KiB) downloaded 2230 time(s).
iode.kinetic1.sm (7.75 KiB) downloaded 2178 time(s).
iode.kinetic2.sm (14.4 KiB) downloaded 2048 time(s).
iode.kinetic3.sm (14.08 KiB) downloaded 6996 time(s).
iode.integrate.sm (10.57 KiB) downloaded 6966 time(s).
iode.test1.sm (22.49 KiB) downloaded 2020 time(s).
iode.test2.sm (22.5 KiB) downloaded 2162 time(s).
iode.Amplitude detector.sm (20.18 KiB) downloaded 2119 time(s).
iode.examples.pdf (416.34 KiB) downloaded 1243 time(s).
iode.kinetic1.pdf (74.06 KiB) downloaded 1075 time(s).
iode.kinetic2.pdf (90.4 KiB) downloaded 1068 time(s).
iode.kinetic3.pdf (88.45 KiB) downloaded 1065 time(s).
iode.integrate.pdf (88.91 KiB) downloaded 1158 time(s).
iode.test1.pdf (116.24 KiB) downloaded 1114 time(s).
iode.test2.pdf (121.64 KiB) downloaded 1042 time(s).
iode.Amplitude detector.pdf (147.71 KiB) downloaded 1140 time(s).
Changes:
- divided into two plugins (the second one is Intel ODE Solver Library);
- version changed (0.2.x.x);
- refactored.
It's hard but I want to realize a general solution for some types of tasks. Specially for this I need more powerful symbolic engine inside SMath. Therefore I made symcs project. I hope that we can use this solution in other similar cases.
That's why I split the plugin.
WroteI think that most of the Mathcad users know what you intend to do and I really appreciate that
Viacheslav is an ancient Mathsoft visitor.
I still have a document from Him ... 2D Implicit plot.
Is possible to code 1/1 Mathcad Given/ODEsolve ?
WroteNo, Jean, 1/1 - not possible. Now they have two different realisations: MC11-MC15 and Prime. But I can do something similar. Plugin can implicity collect information about available ode solvers and you can choose them in the context menu.
I can see you "busy" ! Gorgeous context menu.
What is that Smath Community doing: Building Cathedrals/Pyramids ?
You mean: Mathcad Prime "cluster fuck" in US appreciation from Collab.
WroteSome news.
Hi uni. It is possible to enable a clone of that component for return only the expressions inside? For example, the set of the equations
Also, it is possible too to add the option for mark with a round box the area?
Odesolve() with rkfixed method (Mathcad 15).
Odesolve interpolation test.mcd.zip (8.84 KiB) downloaded 475 time(s).
The same for Mathcad Prime 7.0 (Adams method used).
Bugs will be fixed when the build server starts working.
Links:
1. Cubic spline
2. Cubic Spline Interpolation
Cubic spline interpolation using Mathcad (2009).pdf (256.71 KiB) downloaded 2652 time(s).
WroteOk, I found a bug in rkfixed() and finally figured out the difference between interpolation functions. In the picture below, I repeated part of the calculations from Mathcad. As you can see, to interpolate the numerical solution of the ODE, a cubic spline is used, linear at the end points.
Thanks Viacheslav ... superb demo.
BTW, I was wrong ODEsolve is lspline MCD 11.
Years ago, Tom G. had exposed the different deficiencies
wrt to each l_p_c cubic spline ... Matlab as well.
So, your next headache is to figure the best solver from
the huge Smath library [17], Mathcad stiff is Radau MCD 2001i, 11.
Cheers ... Jean.
