AlgLib 3.1x
AlgLib 3.1x - AlgLib Plugin (based on ALGLIB 3.1x) - Messages
#41 Posted: 12/24/2018 7:47:08 AM
1,555 likes in 1,867 posts.
Updated.
2018-12-24_15-42-32.png 2018-12-24_15-43-00.png 2018-12-24_15-43-31.png 2018-12-24_15-43-56.png
alglib.ode.kinetic1.sm (7.78 KiB) downloaded 1712 time(s).
alglib.ode.kinetic2.sm (10.35 KiB) downloaded 1819 time(s).
alglib.ode.kinetic3.sm (10.04 KiB) downloaded 1832 time(s).
alglib.ode.test1.sm (10.46 KiB) downloaded 1791 time(s).
alglib.ode.test2.sm (10.63 KiB) downloaded 1773 time(s).
alglib.ode.Amplitude detector.sm (19.77 KiB) downloaded 1806 time(s).
alglib.ode.kinetic1.pdf (75.29 KiB) downloaded 1013 time(s).
alglib.ode.kinetic2.pdf (89.97 KiB) downloaded 968 time(s).
alglib.ode.kinetic3.pdf (83.16 KiB) downloaded 938 time(s).
alglib.ode.test1.pdf (85.24 KiB) downloaded 947 time(s).
alglib.ode.test2.pdf (89.96 KiB) downloaded 969 time(s).
alglib.ode.Amplitude detector.pdf (147.84 KiB) downloaded 1000 time(s).
5 users liked this post
bdrunagle 12/24/2018 8:15:00 AM, NDTM Amarasekera 12/24/2018 9:44:00 AM, sergio 12/24/2018 11:04:00 AM, frapuano 12/24/2018 2:22:00 PM, Radovan Omorjan 12/24/2018 2:52:00 PM
#42 Posted: 12/28/2018 2:02:54 PM
Updated. Refactored.
3 users liked this post
sergio 12/28/2018 4:14:00 PM, frapuano 12/28/2018 7:22:00 PM, NDTM Amarasekera 12/28/2018 10:53:00 PM
#43 Posted: 1/19/2019 4:31:14 PM
Updated. al_nleqsolve(2), al_nleqsolve(3), al_nleqsolve(4) added.
File not found. File not found. File not found.
sergio 1/19/2019 5:38:00 PM, frapuano 1/19/2019 6:11:00 PM, NDTM Amarasekera 1/19/2019 11:45:00 PM
#44 Posted: 1/27/2019 5:23:49 AM
With numeric optimization (for all functions) it works much faster.
Fourier series coefficients.sm (17.54 KiB) downloaded 1681 time(s).
Fourier series coefficients.pdf (138.41 KiB) downloaded 979 time(s).
4 users liked this post
Radovan Omorjan 1/27/2019 8:19:00 AM, Davide Carpi 1/27/2019 7:53:00 AM, frapuano 1/27/2019 8:21:00 AM, NDTM Amarasekera 1/27/2019 9:47:00 AM
#45 Posted: 1/27/2019 10:59:21 AM
Example 2.
Fourier series coefficients.sm (28.46 KiB) downloaded 1813 time(s).
Fourier series coefficients.pdf (170.26 KiB) downloaded 1132 time(s).
sergio 1/27/2019 1:29:00 PM
#46 Posted: 1/27/2019 12:48:06 PM
Otherwise w/o Algib and more Engineering applications
Fourier Budapest39 Smoothing.sm (47.67 KiB) downloaded 1726 time(s).
#47 Posted: 1/27/2019 1:06:32 PM
Fourier-Fejer-Lanczos interesting too.
IrfanView "ResizeResample" zoom up/down in two options
Fourier or Lanczos the best.
Fourier Fejer Lanczos.sm (9.11 KiB) downloaded 1623 time(s).
#48 Posted: 2/18/2019 5:42:17 AM
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
Parameterization of implicit functions with al_nleqsolve
Parametrisation.sm (29.88 KiB) downloaded 1720 time(s).
NDTM Amarasekera 2/18/2019 11:46:00 AM, frapuano 2/18/2019 9:08:00 AM, Alvaro 2/18/2019 2:00:00 PM, Вячеслав Мезенцев 2/18/2019 5:50:00 PM
#49 Posted: 2/18/2019 1:59:33 PM
Hi Ber. Nice technique, easy to implement. You can also make that as a function, and monocolor too.
Parametrisation.sm (25.37 KiB) downloaded 1656 time(s).
Another option could be use y0 as vector, and solve for each element in y0, obtaining res, res1, ..., resn
Fridel Selitsky 2/18/2019 2:44:00 PM
#50 Posted: 2/18/2019 11:53:03 PM
1. SS 6179 does not complain
2. Takes ~ 1 hr to terminate the first function
3. NO plot result [NO complain but NO plot ?]
4. Would be interesting checking if the attached SS 6179
runs in your actual AlgLib 3.1x. If NOT => would be a dramatic bug.
It would indicate that all maths based al_nleqsolve would be scrap.
Contour SOLVE [Electron Solve algo Express].sm (20.66 KiB) downloaded 1463 time(s).
#51 Posted: 11/22/2020 4:47:54 AM
Updated.
Changes:
- source code updated to ALGLIB 3.16.0;
- refactored.
#52 Posted: 2/22/2021 4:06:56 PM
Updated.
Changes:
- source code updated to ALGLIB 3.17.0;
sergio 11/17/2021 12:20:00 PM
#53 Posted: 11/17/2021 11:42:24 AM
SMath Studio compatibility
Plugin updated.
Changes:
- source code updated to ALGLIB 3.18.0;
- al_polyroots() function added.
Fridel Selitsky 11/17/2021 12:18:00 PM, sergio 11/17/2021 12:20:00 PM, Alvaro 11/17/2021 1:00:00 PM, NDTM Amarasekera 11/17/2021 4:44:00 PM
#54 Posted: 12/8/2021 2:43:14 AM
Plugin updated.
Changes:
- al_lspline(), al_pspline() fucntions added;
- some functions now have a reduced number of parameters (input vector lengths are no longer required);
- refactored.
#55 Posted: 12/10/2021 1:36:46 AM
Plugin updated.
Changes:
- added support for ODE systems in mathematical form;
- refactored.
sergio 12/10/2021 5:27:00 AM
#56 Posted: 12/20/2021 4:18:35 PM
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
