numeric display
numeric display - numeric display - Сообщения
#1 Опубликовано: 26.03.2024 22:36:24
TopUser2000
TopUser2000
0 сообщений из 28 понравились пользователям.
Hello. Tell me, please, is it possible to see the set numerical values when calculating formulas in the program? I mean, instead
of
a = 5, b = 6,
a + b = 11
see a = 5, b = 6,
a + b = 5 + 6 = 11
#2 Опубликовано: 27.03.2024 09:21:28
churichuro
churichuro
29 сообщений из 79 понравились пользователям.
test1.sm (5,06 КиБ) скачан 1447 раз(а).
#3 Опубликовано: 27.03.2024 16:56:37
TopUser2000
TopUser2000
In the simplest case, this option would be suitable, but if the formula is a little more complicated, then we get a pile of fractions and numbers
#4 Опубликовано: 28.03.2024 19:54:32
Arie
Arie
FYI there has been some discussion about this feature in the past.
https://en.smath.com/forum/yaf_postst23575_Substitution-Optimization.aspx
Also a function proposed here: https://en.smath.com/forum/yaf_postsm78024_substitute-variables.aspx#post78024
#5 Опубликовано: 28.03.2024 23:26:08
TopUser2000
TopUser2000
FYI there has been some discussion about this featurein the past.
https://en.smath.com/for...tution-Optimization.aspx
Also a function proposed here: https://en.smath.com/for...variables.aspx#post78024
But there is no solution for this request there...
#6 Опубликовано: 29.03.2024 02:29:38
There is also this topic.
https://en.smath.com/forum/yaf_postst21565_Show-values.aspx
What you seek is won't be simple, as you requested and applicable however.
This situation is explained in detail by mkraska at the link above.
#7 Опубликовано: 29.03.2024 11:58:56
⚜ Kenny Lemens, P.E. ᵂᴵ
Greetings,
Alvaro has built a function to address this feature request:
Note: it has a little bit of a learning curve, but is worth considering never-the-less.
May this be of Good Help;
#8 Опубликовано: 30.03.2024 01:40:58
TopUser2000
TopUser2000
I don't see the result in the attached screenshots of how it works. A jumble of formulas where there is no clear answer.
